I'll be taking my heads to the skimmers this week. They have done Stag heads before but is there anything I should particularly ask them to beware of, or anything that is good to mention before they wind the cut on? A brief measurement suggests that the heads will only need a light cut, I'm hoping that is all.
Head skimming tips & tricks?
Not the last time Dave, they measured flat on a faceplate. This time I'm being ultra-cautious and making sure the heads are flat by skimming as well as measuring the block faces for flatness. This time I had to encourage the heads to come off which might have left a little distortion to contend with.
Something encouraged a gasket to let go after only 25,000 miles and I would like to be sure I found out what it is. The BGA gaskets seem to be in good condition except where there is evidence of leakage.
As they say where I'm from - belt, braces and a piece of baler twine will stop your trousers falling down!Last edited by mole42; 8 July 2019, 21:56.Richard
Where were the gaskets showing signs of leakage?
This is obviously the bit that needs closest examination.
I am surprised your heads needed encouraging to come off as all the previous examples I have come across, the heads just fall off. Unless of course the BGA gaskets have some sort of sticky surface which I have never come across before on Stag head gaskets.
NeilNeil
No8 here looks a tad leaky....Originally posted by flying farmer View PostWhere were the gaskets showing signs of leakage?
The heads were loose on the block, but both had a single stud that siezed in the head, I had to saw them off after using the rope trick to get anough room for the blade. Last time both heads came off without any trouble at all.Originally posted by flying farmer View PostI am surprised your heads needed encouraging to come off as all the previous examples I have come across, the heads just fall off. Unless of course the BGA gaskets have some sort of sticky surface which I have never come across before on Stag head gaskets.
I will be in the garage again this afternoon with my straight-edge and the feeler guages to check the block, especially around No8.
RichardRichard
the only clusterf*** that my machine shop fell into was trying to skim back local corrosion on the head face which blank against the dead end coolant holes on the block.
Took a pair of heads with shed loads of life in them down to their last skim.
Unhappy was I
I'm fairly sure that I've found the source of the head gasket leakage:
Does anyone know a good TIG welder? The other head is nowhere near as bad as this.
I tried a quick check with a straightedge and a 2 thou feeler guage, I couldn't find anywhere near the rear of the block where I could get slide it under, I'll check further next time.
RichardLast edited by mole42; 9 July 2019, 18:59.Richard
One of my spare heads looked a lot like that before I welded it up, but I haven't had it skimmed yet after I welded it.
Richardthestags experience with head skimming has always been my greatest fear, fortunately it has never happened to me!
I am surprised you had two head studs seize that hard after such a short period of time. Did you forget to use some sort of anti seize compound? I recently had to remove a head on my Estate as I couldn't remove the water transfer housing and that came off easily after nearly 10 years.
NeilNeil
I don't remember what anti-sieze treatment I used last time but it obviously wasn't good enough. What do you use Neil?Originally posted by flying farmer View PostI am surprised you had two head studs seize that hard after such a short period of time. Did you forget to use some sort of anti seize compound? I recently had to remove a head on my Estate as I couldn't remove the water transfer housing and that came off easily after nearly 10 years.
RichardRichard
On the ones I have dismantled I used some of the copper grease stuff, but it does get rather stiff after 10 years.
For the last few years I have been using the ceramic grease used on diesel glow plugs but I haven't had the heads off any of these engines so I can't comment on its efficiency yet!
NeilNeil
