Hi,
I had a droning noise from the rear axle that sounded like a wheel bearing, so I decided to bite-the-bullet and replace the drive shafts with the CV type.
I did find that the O/S rear wheel bearing is badly worn and so hopefully the new drive shafts will cure the problem.
I am also replacing the inner driveshaft bearings and oil seals.
Should I expect to lose Diff oil when I remove the inner shaft bearings and oil seals?
Should I use EP90 GL4 or EP90 GL5 to top-up the diff, the ROM does specify GL5 for Overseas use, but not for British use?
Are there any problems I should look for when inspecting the inner shafts and bearings or are these normally fairly robust?
Also, I am advised to tighten the outer stub axle nut to 290Nm (214 lb/ft) on the new CV driveshafts, which is much higher that the 120 lb/ft suggested for the original outer stub axle nut.
Does anyone know if this is correct?
Thanks,
Den
Thanks,
Den
