Hi all
I discovered a fuel leak in the pipe that goes from filter to carbs in the engine bay. When I took the pipe off, I found out that it wasn't a 5/16 pipe, but more like 1/4".
I went to my local motor factor's and bought some 5/16 pipe for unleaded fuel.
On fitting it and reassembling the air filter etc, I see that the pipe is touching both the air filter elbow and the cam cover (slightly compressed at this point). Is this a safe arrangement or will the heat from the cam cover affect the rubber pipe. Don't particularly want another leak spraying fuel around when hot.
Gord
Gord
