Hi all
Yesterday I installed new Magnecor leads. With them, I am running the Bosch Red coil and Bosch WR8DC plugs (as installed by Faversham and renewed by me).
Today I was running along beautifully en route to Hampshire when I heard a pop and the engine started misfiring. I nursed it home, clearly only running on 6-7 cylinders.
After testing the new leads and checking for any ripped diaphragms in the carbs (all fine), I took out #1 spark plug to find it basically melted and burnt - see attached.
I then took out all the rest of them and found varying degrees of black burn. A photo of #6 cylinder is also attached.
Does this mean the Magnecors + Bosch Red + Bosch plugs are incompatible? Does the Bosch Red coil pump out more/stronger spark and with the addition of the Magnecors with less resistance mean I am toasting them?
Any ideas?
Jeff
Any ideas?
Jeff
