Hi
I continue to have a misfire when hot after the car has stood parked and shut off. Once I start moving again, the misfire eventually stops and never misfires throughout the rev range as long I as I am moving. I have not been in standstill traffic for a while so I don't know what would happen in those circumstances.
I dread to bring up this confusing subject again, but am I running a suitable coil? I am running the Bosch Red coil that so many on here run and my car is 1976 Mk2 with no ballast resistor. Just to confirm I have an older Luminition optical ignition, new distributor cap, new plugs, new rotor arm, and brand new Magnecor leads. The coil is not touching the engine, but is still mounted in it's original position.
For the life of me I cannot figure out which coil is suitable for this setup, or if the Bosch is fine, what the hot misfire could be attributed to.
Jeff
Jeff
