I've bought new Top Mounts, Springs, etc from SOC spares to rebuild the front Suspension. The top mounts have a small half moon shape indent visible from the top - is this there to enable correct orientation when fitting, and if so how do you use that to get each side correctly fitted?
Also, does anyone have any guidance on the correct lubrication to use when fitting the outer sleeve and inner bearing into the top mounts for both the fitting itself and for subsequent good life and performance 'in service'? I assume that a good application of grease is required to allow rotation and to prevent corrosion - or is something else better?
Thanks.
Thanks.
