Master cylinders removal, again book wrong
    Book says take out the servo ( as if you can get to one nut) But I see by searching that is not necessary. Never was on any other car. So, disconnect the lines, off the two nuts, but it feels like it is being held in by a spring or something. Can't find a decent cross section. Book just says "remove" What is up before I pull real hard and have to order big expensive things I destroyed!
    OK, got the darn thing out. Just hung up.
    Then I find out, no mater how many times as read the forum on " a spring you unwind" no way am I getting the spring retainer out, and then read about getting the circlips out and the nylon plunger. OK ordering a new one along with the o-rings for the PDWA. FWIW, the Rimmer master cylinder kit did not include the o-ring between cylinder and booster.
    Guess this is why the manual does not have procedure for rebuilding. It would take more labor hours getting it apart than putting in a new one.
    Seems brake cleaner is not compatible with DOT 5. Alcohol?
      For future reference (!) perhaps you forgot to kill the vacuum in the servo before removing the master cylinder. You need to pump the brake pedal till it goes "Hard" to do this.
      It is the vacuum that tends to hold he cylinder in to the servo.
        When I changed my master cylinder,. I could not get it off with the servo in position, so had to remove it as a unit. And then, yes, the master cylinder was "stuck" into the servo, and I was very puzzled as to how it was supposed to release until I applied a little more "force" and it separated. I fitted a complete new master,. Works perfectly.
          LD-Parts sell a master cylinder with a stainless steel inside lining. Very recommendable, as no more rust insinde the master cylinder....
          Good luck,
          Dieter - from Germany.
            LD. I'll check them out. Thanks.
