Hi all, Hopefully you experts out there can help me with my latest conundrum.
I have a single integral garage that is constructed under the house so that 2 walls are underground and 2 walls are exposed to the outside. The construction is insulated cavity walls with an insulated sectional overhead door. There are no windows and the garage is unheated (there is a radiator but wife won’t let me turn it on). The lowest temperature I have ever seen in the garage is 11°C. Generally the RH in the garage is about 70-85%
For over winter, I have put the Stag in there and connected up a Maeco Zambezi desiccant dehumidifier plumbed to drain outside. This maintains the air RH at about 50%. Trouble is, it is looking like it is going to cost at least £25 a month to run.
I have now put the Stag in a bubble Carcoon that the previous owner gave me and put the dehumidifier inside the carcoon to maintain a RH of 50% which is OK but the garage is still at about 55-60%.
I understand that the bubble will be expelling dehumidified air out through the zips into the garage which will then get pulled back in to the bubble in due course. So in effect the whole garage is getting dehumidified all the time (and pulling untreated air in from outside as well).
I also understand that a carcoon on its own works on the principle of air movement therefore drying any moisture off the car surfaces. But at the end of the day if the garage wasn’t dehumidified it will be pulling air in at 75-85% RH.
Will air movement at say 70 – 85% RH in a carcoon be sufficient to prevent any deterioration of the Stag or will using a dehumidifier be better?
Or doesn’t the RH% matter as long as the vehicle temperature is kept a few degrees above dew point as per painting procedures?
So which is the best solution:-
I have trawled the internet and on here but can’t really find anything definitive.
I have just read on the Carcoon Veloce web site “Air circulation is provided by Carcoon's patented Active Airflow Concept that comprises of two air treatment units which operate continuously to provide super-atmospheric, circulating airflow for 24-hours a day, 7-days a week. Importantly, the circulating air is taken from inside the storage unit itself, which effectively isolates the flow of air from the outside environment”.
If this is correct then it will probably be the solution in conjunction with a dehumidifier circulating the same air (except the times when the Carcoon is opened up to access the car). I shall check with Carcoon.
Thanks for your patience in reading, I might have asked the same question twice here! I look forward to reading members views.
Confused, Mark
- Keep bubble Carcoon with fan only inflating the bubble and keeping air movement albeit at 70-85% RH?
- Keep bubble Carcoon with fan inflating the bubble and keeping air movement AND putting the dehumidifier in the bubble with drain to outside. So get air movement and maintains RH at 50% (expensive as dehumidifies the air in the garage as well)
- Buy a Carcoon Veloce framed car storage. Run the intake fans keeping air movement albeit at 70-85% RH?
- Buy a Carcoon Veloce framed car storage. But don’t run the intake fans, put the dehumidifier inside with drain to outside. This may work out less expensive to run because not having to dehumidify fresh sucked in air all the time but may be less air movement inside the storage due to fans not running.
Confused, Mark
