PWDA valve
    PWDA valve
    How do you get the PWDA valve apart ? ive undone the big nut but cant get the valve to move
    Use an air compressor to get it out. Also putting a small pointy thing in the hole, and levering it, where the brake warning thingy goes into helps.
      Dave, be careful! When you use an air compressor, that little "shuttle" comes out like a bullet. You can as well press it out with a grease gun.
      Good luck!
      Dieter.
        I just banged on on he table real hard and the piston popped out. It may be a lot harder if corroded. Mine was not.
          At the moment ive got mine soaking in WD40,as i think its corroded
            Thanks for feedback got a air blow tool on order
