I have a new front valance to fit at the same time I will be fitting lower front wing repair panels.
I can see I will struggle with access to do any plug welds on the valance/ wing joins and A few daps of braze on the outside of the joint would open up the flanges to corrosion on the inside as they flex apart. So I was considering Drilling both flanges and securing the each join with five 5mm stainless nuts and bolts and suitable spreading washers.
The advantages are that the panels can be fully rust proofed with a continuous bead of sealant run on the flange before it is bolted up.
Not original but hardly reducing any critical strength in the structure.
Can anyone suggest any reason why this should not be done? - Alan
