Diff backlash
    Diff backlash
    A while ago Russ posted a video of him repairing a Diff with wear on the planet wheels/gears, any one know where i can find it
    Thanks Dave
    [QUOTE=new to this;n789173]A while ago Russ posted a video of him repairing a Diff with wear on the planet wheels/gears, any one know where i can find it
    Thanks Dave
    [/QUOTE
    Here you go Dave. Happy New Year!
      I think Russ took down the videos; or put them somewhere else, and I couldn't find them elsewhere when I was doing my diff.
      Drew
        any surprise when he gets called ‘permanently banned’ on a forum he gave so much to ?
          The original thread is here:
          The links to the videos no longer work, but there is still some useful info in the thread.
            This is a video I made when checking the diff - not sure if it helps, but my clonky diff disappeared after re-shimming. Glad if I can help anyone with a Stag.
            Drew
              Drew
              Drew
              video doesnt open
                [QUOTE=Arbman Al;n789174]
                Thanks Dave
                [/QUOTE
                https://www.socforum.com/forum/forum...al-play-a-cure
                Thanks al Happy New Year to you,are you going to Stoneliegh in Febuary
                  Drew
                  video doesnt open
                  ok. I'll have a look into it. it's my first video ever uploaded to youtube
                    Try it now. It should have worked for anyone using the link, but it's now open to all (hoping I won't now be spammed to death).
                      That works ok, shows exactly where the problem lies.
                      I must have re shimmed half a dozen diffs now, some of them twice, they seem to need it every 50,000 miles or so.
                        question for those in the know
                        is it possible to remove the cross member and diff rear case with the diff in the car? or is it an everything out job?
                        thanks Phil
                          It's an everything out job - but the hardest part is removing the exhaust from behind the diff. Once that's out, there's not a lot of trouble dropping the rear diff mount.
                            Hi Neil,
                            On my second whinney diff,could you please tell us best place to get the shims from
                            TIA
                            Regards Mark.
                            P.S been meaning to ask you on your 250 bhp Stag engine ,did you lighten the flywheel?
                            thank you
                              thanks Phil
                              The bolts at the top of the diff case would be hard to get at with the cross member in place
