I note that the engine number should be stamped on the back of the engine block, behind the distributor where the engine is bolted to the bell housing. My engine is out of the car and I cannot find the number. Can someone show a photo of their engine number (please delete part of the number if sensitive) to help me locate mine? We bought the Stag in 1985 and cant believe the engine block does not have a number. Thank you
Engine number location photo
Make sure when car being inspected in case you don’t know the chassis/vin number is on the plate on the b post of Lh door, Ignore numbers on front bonnet skuttle as this is body number used for identification while body being built and should be painted. The second unpainted plate is a sales number. Hope that helps.
