Since I rebuilt my carbs (Strombergs) I've got a problem with the idle. If I blip the throttle it revs and then drops back to idle - just like it should, but if I release the pedal slowly the revs don't drop below about 1500. I can get back to idle either by blipping the thottle or giving the linkage a gentle push on the plate where the link rods are attached, or by closing the lever on the carb spindle up to the idle screw.
I think if the springs on the carb spindles were stronger the problem woudn't exist, so is it possible that I didn't wind them up enough when I fitted the new spindles, on the bench there seemed to be enough spring force to close the butterflies - I'm wondering if it's possible to get another full turn on the return springs?
Any suggestions for other causes or solutions, I guess it could be that the butterflies aren't quite centred on the spindle, or the spindles are bindingwhere they go through the carb body....
Thanks, John.
Thanks, John.
