Lifting the Stag?
    Lifting the Stag?
    Has anyone tried one of these?
    This mobile lift is ideal for any workshop, mobile mechanic or DIY enthusiast. Lightweight and very portable, no need for any air or power supply. Features • 1500Kg capacity • Lightweight design 58Kg • Vehicle can be tilted forwards or backwards • Supplied with manual handle • Supplied with bracket so that a drill can […]
    I have limited space in my rented garage, one of those seems a better option than a pair of ramps!
    Opinions gratefully received
    I’d be a bit worried about the capacity which is listed at 1500kg. Stag Kerb Weight is 1375kg, so very close to maximum. I would be asking what their certified factor of safety is. I’m used to a f.o.s of 6 for lifting gear, so it should be tested to 9000kg to achieve that.
      I have the next size up got mine from CJ Auto,there okay they lift and lock in place,on mine i can adjust the width,mines a manual wind but you can use a drill to wind it,pay a bit more and get one that automatilly lifts
        Julian (jleyton) posted several pics of his in use some years back. with "advanced search" you could find them
          Julian's came from CJ Autos, but I don't know which model: https://cjautosheywood.co.uk/product...ory/car-lifts/
          Post 13: https://www.socforum.com/forum/forum...ssor-lifts-etc
            Pretty sure Julian has the 3 in 1
              I had a cj autos one, very good I had the 3 in 1 and used an electric drill to lift it. dont forget to remove the locking pin before you lower it, you can snap the drive shaft! guess how i know, derek
                You will be able to see Julian's stag in next month's Triumph world.
                Cheers Glenn
                  Does anybody know who manufactures these independent 4-wheel lifts? any good for working underneath or are they just for show?
                  Jeff
                    https://www.cjautos.eu/product_p/cr012.htm ?
                      Thanks dasadrew! Didn't see it on their page...
                        These are the ones I have had for a few years and am very pleased with them. Good for my Stag and E-Type and when I bought them saw them demonstrated on a new Mustang! Very stable and can take the wheels off the car whixh is a limitation of the ones which lift the wheels.
