I had a thought that may or may not come through but it was interesting experimenting
Some say that the mechanical fan needs to stay because it provides some airflow around the engine, my thought was why can't an electric fan do that? If I run it at a slow speed until its needed it would provide at least some some constant flow. the relays to achieve this were not difficult to work out, I wanted the Davis Craig fan controller to give full speed weather ignition was off or on but the low speed to come on only when ignition is on, until the controller asked for full speed.
I dug my fan out and despite a specification of 17A found it was running at 22A (300W) and its a bit of a beast! The resistor I had was 0.3 ohm. When I ran it with the resistor it calmed it down to what I would usually consider "normal" which I felt was still a bit too much. Also, as beefy as the resistor looked after about a minute it started smoking!! -- To the online calculators --(I used to be able to do this manually back when I was a boy!) and in theory this would mean about 14A @ 8.5v at the fan(122W) and when I actually measured it thats what I saw. So far so good.
I played with the calculators a bit and decided to try a 0.5 ohm resistor rated 100W which would drop the fan down to 12A @85W (75W on the resistor) I found a great resistor from an electronic supplier with chassis mounted heat sink and spade connectors,$12 so ordered it
Terry
Terry
