I need to rebuild the brakes which I planned to do last, but with this shelter in place order,  . Is there any harm in replacing the seals and pistons and letting the car sit? Is there some sort of brake grease I can use to prevent anything from seizing? The car wont be on the road for some time.
Rebuilding brakes
 Normal brake fluid will keep the internals "safe", so long as you use fresh stuff (i.e. hasn't had a chance to absorb any moisture), Otherwise I can't think that you would need to"grease" anything else, as brakes live for a long time without any lubrication anyway. Certainly don't use copper-ease on brakes.
 - Likes 1
 Can I use this on the bores of the rear cylinders? I don't plan on beading the system any time soon. Or should I just coat the bores with fresh brake fluid?Originally posted by Phil S View Postif it's the seals on the piston you want to grease then there is a specific red brake grease available in small tubes, you wont need much.
 Whilst you have the rear brakes in pieces spend some time looking at the handbrake levers 519070 & 519071 they wear - but not very apparent and the hand brake is then almost totally ineffective. It was only when I bought new ones that I could see the issues.
 Just so easy to replace when the brakes are apart.
 Alan
  Order your Brake Shoe Adjuster Kit - AAU8994 ⛽ Low prices and fast, worldwide delivery ✈ British car experts ♚ Call ☎ 01522 568000 or ☎ 1-855-746-2767 Order your Brake Shoe Adjuster Kit - AAU8994 ⛽ Low prices and fast, worldwide delivery ✈ British car experts ♚ Call ☎ 01522 568000 or ☎ 1-855-746-2767
 These adjusters are the same as Rover SD1,TR7 and Triumph 2000/2500,
 Fitted these to mine years ago and made a real difference,Ken.
 Mike,
 I bought mine from Peter at Ldpart. I'm talking519070 and 519071.
 Prior to fitting them the hand brake cable seemed too long and I could not get it tight enough so the handbrake was useless and I could not park on a gentle slope outside my house to open the gate, there was too much lost movement in the pin.
 After fitting and no other changes I have not found a slope the handbrake cannot hold the car on.
 Alan
 AAU62456PAIR
 This kit at Rimmers is for sd1, but incorporate the same adjusters as the stag,but I don't know if any of the other components are shared with the Stag.if they do it might be better value.
 I was talking about the adjusters earlier,as they are what made my handbrake work properly.(they have certainly gone up in price though,Ken.
 That is my experience too. Replace the levers and you don't need extensions.Originally posted by wilf View PostIf you replace the inner levers, so that the wear on them is eliminated, you don't need those. I suspect they were making up for that wear.
 The extensions were a Triumph development for rally cars, presumably to make handbrake turns easier....
 RichardRichard
