Hello all! Hope you are keeping well.
My name is Kyle! I bought my first Stag earlier this year - my last car was a Dolomite 1850 which I used as a daily driver for 5 years until the bodywork went. I went for the best body I could afford on the Stag, and will use it as a daily driver too eventually.
When I bought the Stag, it hadn't moved for a few years, and I've since done a good few thousand miles in it and blown a head gasket (among other things!). Today I drained the fluids, removed the ignition electrics, Removed the LH exhaust manifold and removed the carbs.
I have the 2-nut tool for removing the studs from Rimmers that I tried (very ineffectively!!) to remove the studs on the 1850 with. I haven't tried on the Stag yet.
I have a few questions please!
1. Does anyone have a head puller I can borrow in Sussex please? I don't mind paying for it and collecting/returning.
2. What are the thoughts on nickel-plated studs?
3. Where is a good place to get heads/inlet manifold skimmed correctly so the inlet manifold still fits?
4. What are good head gaskets/where can I get them?
5. What work should I get done on the heads?
Thank you so much!
Kyle
Thank you so much!
Kyle
