Warning: Trying to access array offset on value of type null in phar://.../vb/vb.phar/bbcode/url.php on line 2 Notice: str_replace(): Passing null to parameter #3 ($subject) of type array|string is deprecated in phar://.../vb/vb.phar/string.php on line 3 CV Driveshafts - Stag Owners Club Forum
CV Driveshafts
    CV Driveshafts
    Taken my rear suspension off during the enforced period of no golf, to find one of my CV joints is knacked. The cage holding the balls to the inner race is cracked which is annoying. Have contacted SC, they're seeing what they can do to help. No receipt unfortunately, the shafts came with the car.
    Anyway the main reason for posting this is to give any of you with these fitted who didn't fit them personally (or have them done for you) a heads up that because of the vagaries of the Stag rear axle set up you need to have a spacer between the diff output flange and the driveshaft sliding joint. SC have sent me the info to measure but worth checking you have spacers if you have these driveshafts fitted.
    Changed the diff seals and pinion bearing as well as looking at the poly bushes. The trailing arm ones are fine but the big subframe ones have some damage so not quite fit and forget. I don't know how long they have been there.
    Still the trailing arm and subframe have come up ok. Why would anyone put underseal on the trailing arms?
    My driveshafts look awfully similar to these, but are from Rimmers (311914CV) manufactured by CDD I believe.
    I have no spacers fitted, but I don't think there is much room for them, here is only a relatively small amount of lateral play as there is.
    Could you copy me with details of what you need to measure, order and fit please?
    Thanks,
    Den
      Hi Den, mine are definitely from SC and look like this Screenshot 2020-04-09 at 15.18.12.png
      The Rimmer ones do indeed look like CCD ones which are visually different, not sure about internals. I would think calling CCD to ask them would be better than using SC methods on non-SC products just in case you don't need to do anything?
        What did you clean the trailing arms with
          Chisel. Wire brush in drill. Thinners Dave. I then gave them a dust of etch and a couple of coats of silver cos even cleaned up as well as I could they looked average. F7EC2D3D-74E6-4E48-AE08-652A5EC41096.jpeg
            The ones sold by Rimmers are CDD units as I’ve had confirmed by CDD themselves, the SC ones are not the same. The CDD ones listed for a Stag are made specifically for the Stagand do not need additional spacers.
            The SC ones are generic I believe and have to be adapted for different cars.
              https://www.limora.com/en/reaction-shaft-199072.html I believe these are the sc drive shafts .The site shows spacers .
                Correct
                  Mine are Ccd .I ordered from robsport at stonleigh as they were cheaper than CCDcould do even though they made them .
                    Originally posted by Seaking View Post
                    Mine are Ccd .I ordered from Robert at stonleigh as they were cheaper than CCDr could do even though they made them .
                    Hi ,Is that meant to read Robsport,or can you say which company,
                    thank you
                      thank you
                      Sorry yes Robsport.
                        [QUOTE=Goldstar;n794310]Taken my rear suspension off during the enforced period of no golf, to find one of my CV joints is knacked. The cage holding the balls to the inner race is cracked which is annoying. Have contacted SC, they're seeing what they can do to help. No receipt unfortunately, the shafts came with the car.
                        From the original post you could get these races repaired by a qualified engineer/wielder. However, these are more than likely from a mainstream car eg Ford Mondeo. I very much doubt these are a one-off made just for the Stag.
                          Thats a bit alarming i always thought ploy bushes were fit and forget, i was going to fit ploys to my car in the same area,do you know how long they been in place ? and you also get different Quality bushes what make are they
                          on your trailing arms have you but clear lacquer to protect the paint/shine
                            Ive looked on the site cant find spacers
                            bit confusing two drive shafts look the same but from different manufactures,one need spacers the other doesnt
