Hi, My mk2 wipers will not park, they operate ok on slow and fast speeds. I have stripped the motor and the brushes are within the minimum lenght at 7mm for earth and slow and 9mm for fast. I have read all the other posts on the park switch and as far as I can tell there should be permanent power to the green wire at the park switch. I have 12v there. I have cut open an old park switch as attached pictures. as far as i can see there is no physical connection between the permanant live and the slow speed brush. the 3 connections on the switch are permanent live (green) left connection, intermitant feed green/brown in the normal position and pemanent live (green) and the earth brush (blue green) (black on the plug) when the switch is depressed. I have obtained a new park switch (for a jaguar XJ6) and they still won`t park. Am I missing something? all help appreciated, thanks in advance Derek (sorry for the repeat pictures I cannot see how to delete them)
2020-04-06 13.52.01.jpg2020-04-06 13.52.15.jpg2020-04-06 13.52.15.jpg2020-04-06 13.52.50.jpg2020-04-06 13.54.17.jpg2020-04-06 14.05.45.jpg2020-04-06 13.52.15.jpg
