This will be my fourth attempt at trying to stop the ATF from leaking out of this gasket and before I go ahead I thought I'd ask the SOC collective for their suggestions, here's a history of what I've tried for each of the three sealing attempts so far.
Its worth noting that each time I've used a new gasket from different reputable Stag suppliers (LD, Rimmers & Paddocks) and in each attempt I've thoroughly cleaned all sealant residue before fitting the new gasket.
1. This attempt was using Hylomar Blue both sides of the gasket and using thread sealing compound on the bolts before tightening them up.
2. This attempt used silicone sealant both sides of the gasket.
3. This attempt used flange gasket sealant both sides of the gasket.
For this 4th attempt so far I've removed the sump and cleaned up both metal mating surfaces. I've checked the flatness of the sump faces using a steel rule and shining a light from behind which showed very little warp (if any) between any of the surfaces. Checking the flatness of the gearbox mating surface isn't so easy but I have rubbed over the surafces with 1500 wet and dry which revealed that a few of the threaded holes seem to have raised themselves proud of the surface - almost as if when the bolts were tightened that the thread had started to distort - none of these raised areas were what I would have thought were significant enough to cause the leak.
Once again I have a new cork gasket ready to fit and I happen to have a tube of Wellseal in the toolbox. I've never used this stuff before and I was wondering what you guys would think if I tried to use this for this attempt.
All suggestions for how I try and make this 4th attempt successful would be most welcome.
