Ignition barrel pin
    Ignition barrel pin
    This is the pin that holds the ignition barrel in, if anybody was wondering on the type/size. It measures about 8mm long x about 3mm thick with a 3.5mm head. Butchered the old broken barrel to remove, but will drill out the pin on the current barrel so I can refit the original. Saves multiple keys. IMG_20200418_130152140.jpg
    Mark
    not had a stag one apart to comment but many makers spring load these, key in the lock, push the pin inwards and withdraw the lock with the key
      a local lock Smith old guy. drilled out the pin of one of mine. he drilled at an angle and was able to get something underneath to pull it out. there is one part in the lock that breaks so keep ur parts. the guy was able to make a good ignition switch out of two.
        You could be right Phil. didn't try that. it was just bugging me so had to get the original barrel out.
        mark
