Testing fuel pump
    Testing fuel pump
    There has been a few recent posts on fuel pumps and systems etc but I would like to know what checks I can carry out on my pump which is currently off the car. It is the original pump since 1977 and the car has been in storage since 1987. I tried connecting a 12v supply across the terminals but nothing. Not even one click. Any advice greatly appreciated.
    1978 Stag Brooklands Green
    If it's not ticking then the pump is faulty - it should tick fast when on the bench.
    You need to repair (http://sucarb.co.uk/su-fuel-pumps-sp...-pre-1985.html) or replace or (even better IMHO) repair and upgrade your existing pump to electronic with a Burlen conversion kit (http://sucarb.co.uk/su-fuel-pumps-sp...arth-12-v.html).
    If you replace the pump make sure that the output pressure of the new pump is within spec (many 'replacement' pumps output too much pressure and cause flooding issues).
      John. If it has been unused for over 30 years, it is hardly surprising it didn't burst in to life. It may only be necessary to take the cap off the end, and clean the points with some fine sandpaper. Worth a try I would have thought.
      Mike..
        I cleaned the points on mine it came back to life. I knew it worked before. It was just leaking.
          Afternoon all,
          Have you tried the age-old mechanic's cure of a good "thwack" with either a plastic or hide-faced Thor hammer (ah, the good old days !!) or the butt end of a conventional hammer ??
          If still "no tick" then time for points file/contact cleaner..if still no go, time to dig deeper. Best of luck.
          Neil.
          '77 Tahiti Blue, Spax, MoD, poly-bushed.
