Evening all. Used to be a member some time ago, but other things got in the way of my Stag (owned since 1999) including a sailing yacht and a campervan.
But during these times, I cant use either of them, so turning attention to the Stag and some much needed TLC, mainly around the soft top and frame.
In 2 weeks, I am being furloughed from work for 3-4 weeks, so a good time to do whats needed on the hood and frame, but looking for some guidance please?
The old hood has been removed and now I'm working on getting the frame right. The header rail has been bodged at some stage, so have now re-made the pivot plates and welded them back into position. What I cant find is a replacement for the rivets (RF2814) and they seem to be NLA? What can I use instead? Have seen suggestions of using flat head coach screws in M8 size and square nuts? Would that work? Is it better to use mild steel or stainless if I can get them? Or what else can you recommend?
Secondly at the rear of the header rail is what I would term a crash pad or bumper? The old one is a semi circular shape made of what looks like cork? Again, what can be used to replace this with? I'm thinking high density foam, but where can I get that from? Also, should the top edge of the header rail be covered with a foam material as well? to give a better finish to the outer edge of the new soft cop material?
Thanks in advance!
Thanks in advance!
