Any Thoughts on this please. Did 90 mile round trip to work to day and on the return leg aprox 3 mile from my home I could smell a sweet hot smell. Pulled in to my drive to see a trail of auto transmission fluid. Look under car to see it pouring out from around the gearbox sump. I recall it doing this when I bought the car and did a 30 mile trip, same thing but not as much. Same again I let it cool before I moved the car in to the garage. Gearbox is working fine. My thinking Is that the fluid is getting to hot after a 30 mile plus run and is being forced out some where. Could the oil cooler be blocked or restricted.
I'm going to get the car up on ramps tomorrow a, to clarify its BW 65 box and to see if I can see where its all coming from.
Any help would be great
Simon
Simon
 if that’s correct, the procedure to change the front seal is easier than the type 65. The box comes off the converter housing from underneath. Requires careful reassembly as the converter drive lugs must pass through the new front seal without catching / damaging.
