These a thick white with red strip wire that goes from the Starter (STA connector) if automatic  via inhibitor switch  to ignition switch .
Do i need this wire if Manual ?
The wiring loom in engine bay connector for manual has the wiring for gear box reverse and overdrive switches on gearbox , the thick White red is looped back onto the connector .
My connector block wires have all come off ,Question is does the loop back white red feed any thing ,or is it there if auto fitted ?
Can i remove it ?
Can i remove it ?
