1973 Mk 2.Starts as normal, then after a few miles occasional hunting and stutter. Noticeable when under load. Eventually very poor running.Have a suspicion its the ballast resistor. Checked the voltage to the + side of the coil when ignition is in the on position, it's showing 12 volts. Am I correct in assuming it should be around 6-9 volts ? I again am assuming if the coil is getting a continuous 12 volts its overheating. If it is the ballast and I want to keep the existing coil is the only option a MK1 type ballast ? Or are the resistored white and pink wires still available ?
Thanks for your help
Tim
PS Just been out again checked with multi meter when running. Its showing just over 9 volts. which I assume is correct. Looks like it might be ok and not the problem I thought it was .
Tim
