AIR LOCKS.
    AIR LOCKS.
    Hi all, filling the Stag cooling system has always been a pain, I think I've found the solution, it's an aftermarket bleed valve, I intend fitting this as high as I can in the heater upper hose, leave it open as you fill the system and Bob's your uncle ! Martin.
    Hi Martin
    Where did you find this? & how much?
      jleyton wrote:
      Hi Martin
      Hiya, it's an ebay shop, email is, andygoodliffe@yahoo.co.uk the item number is 300404674565, it's described as Caterham, Westfield, Kit Car, Bleed Tee/ coolant tap. £4.95 plus the usual. Martin. PS ok Ian ?
        This is similar to something i made up for a kit car i built manyyears backout of a couple ofplumbing copper fittings and a bleed screw.
        Andy.
          Here's my take on the subject.
          Cheers Steve
            Steve, if your engine is running a bit rought you might want to check your HT leads :P.
              Mines a V1:P
