In the process of fitting an A/C system I decided to move the bonnet release cable to the RHS which frees up a bit more space for A/C pipe work on the LHS.
I ended up just reversing the cable by threading it through the fixed support on the release lever in the engine bay and then attached a cable clamp on the end of the wire. The cable was passed through the firewall hole where the wiring loom is on the RHS and the bracket with the pull handle then screwed on to the side panel so that it sits just under the dashboard.
While I was at it I also fitted an emergency bonnet release cable so that when the main cable fails at the worst possible time, I can quickly still open the bonnet. I did this by using some left over wire , an old welding machine outer wire cable cover and some small aluminium crimps. I made a loop in one end and fitted this over the bonnet release lever in the engine bay, then passed the wire and its cable cover through the same firewall opening where the bonnet cable was, made a small bracket and attached it to the bottom of the bonnet release handle bracket and made another loop on the end to allow a finger to pull on it.
Pleased to say they both work a treat and must be one of the easier mods I have done on a car in a while......which makes a change
