windscreen rubber
    windscreen rubber
    Hi. Im about to refit my windscreen I have read about the two different size trim gaps / rubber seals, my trim is the wider lip type 15mm does anyone know where i can buy the wider
    type ? Hope i have made myself clear
    Chris
    Windscreens are also different thicknesses. You'll have a right good laugh fitting the screen and trim.
      Chris.
      Only one type of screen rubber is currently available, and that has the deep groove for the wide lip, so you are in luck. If you have the shallow lip, the problem is getting the stainless steel trim to stay in place.
        Hi mike .when i rung paddocks they said the rubber seals they have are for the narrower gap in the trim .so the ones they have wouldnt hold my chrome trim in.I was
        wondering if they only do one rubber seal all the wide gap chrome trims would be obsolete. have mailed
        rimmers asking them but not had any reply yet .,
        regards
        Chris
          Suggest you also look at SOC Spares and Robsport. Good folk
            Phoenix have a good catalogue showing sizes.
              Chris.
              Perhaps I am mistaken, but I was told that with a deep slot in the rubber, at least both trims would fit, but the narrow one would be a bit loose. If they had made a shallow one, then the wide ones wouldn't fit at all.
              They weren't prepared to make both. I will try to confirm that shortly.
              Mike..
                Try https://www.coh-baines.co.uk
                https://coh-baines.co.uk/wp-content/uploads/2018/06/Triumph__27777.jpg
                under ES 86 just purchased one myself £33 Inc vat and delivery
                cheers Glenn
                  The one SOC Spares sell is from Baines I believe.
