Rear wiring loom, left side
    Julian gave us great deal of valuable information, his departure was a great loss to this forum.
    Indeed. He still takes a look now and again........
      This is something that Julian Leyton published on here years ago which is very helpful:
      B Black G Green K PinkLG Light Green
      N BrownO Orange P Purple R Red
      S SlateU Blue W White Y Yellow
      BROWNMain battery feed, ALWAYS HOT & unfused
      PURPLEAuxiliary not via the ign switch, ALWAYS HOT & fused- from fused 1-2
      GREEN HOT with ignition ON & fused--from fused 3-4 or 19-20
      WHITE Base colour for ignition circuits, HOT with ignition ON & unfused
      REDSidelights, instrument lights, rear lights, fused or unfused
      BLUE Lighting - Headlight feed to main/dip/flash switch
      BLACK Earth connections
      BP Brake differential pressure (PDWA) switch to brake warning light
      BW Handbrake switch to handbrake warning light
      GB Fuel sender to gauge
      GLG Gearbox/seat belt switch to LH belt switch & RH seat switch
      GN Reverse light switch to lights
      GO Low fuel sender to low fuel warning light
      GP Brake light switch to lights
      GR LH turn signal
      GS Blower switch "high speed" feed to blower motor
      GU Temp sender to gauge
      GW RH turn signal
      GY Blower switch "low speed" feed to low speed resistor
      KW Ballast resistor wire to ignition coil
      LGB Washer pump from steering column switch
      LGK Hazard flasher unit to hazard switch
      LGN Turn flasher unit to steering column switch & hazard switch
      LGO LH belt switch & RH belt switch to Fasten Belt light
      LGS Hazard switch to turn flasher
      NLG Wiper park switch, delay relay circuit
      NY Ignition warning light to alternator field
      PB Horn switch to relay
      PK HRS after PU from fuse 22
      PN Ignition controlled relay to fuse 21-22
      PO Interior light switch to RH console and roof lamps
      PR RH door pin switch to RH puddle lamp & interior light switch
      PS LH door pin switch to LH puddle lamp & interior light switch
      PU Blower motor & First part of HRS (before Purple/Pink to switch)
      PW Interior light switch to LH console & roof lamps, boot & glovebox lamp circuit
      PY Horn relay to horns
      RB Fuse 5-6 to LH front park lamp, LH tail lamp
      RG LH parking lamp supply from master light sw, to ign switch to RH lamps w/ ign on
      RLG Wiper normal speed
      RO Fuse 7- 8 to RH tail lamp, RH front park lamp, instrument lights
      RW Dash panel lights from rheostat
      RY Front fog light feed from master light switch
      S Window lift relay to window lift CB & overdrive circuit fuse 23-24
      SG Window lift CB to window switches, RH window switch to RH window motor
      SN LH window lift switch to LH window lift motor
      SP RH window lift switch to RH window lift motor
      SU LH window lift switch to LH window lift motor
      UK LH dip beam
      ULG Wiper high speed
      UR Fuse 15-16 to RH dip beam
      US LH main beams
      UW Main/Dip/Flash to fuse 11-12 & 13-14, main beam warning lamp, fuse 13-14 to RH main beams
      WG Heated rear screen switch to heated rear screen & warning lamp
      WK Ignition Switch "Acc" - radio feed
      WLG Wiper delay circuit
      WN Oil pressure sender to light
      WR Ignition Switch "Start" through auto trans inhibit switch to starter solenoid
      WS Tach signal from ignition coil negative terminal
      WU Choke cable switch to choke warning light
      WY Starter solenoid to ignition coil--supplies full voltage to coil while cranking
      Y Fuse 23-24 to overdrive switch
      YP Overdrive switch through overdrive gearbox switch to overdrive solenoid
      [ATTACH]n801635[/ATTACH]
      That's REALLY helpful!
      but riddle me this... I've got a loose slate with black stripe hanging around behind the dash... What's that for?????
        It looks like its part of the aircon wiring, around the condenser relay and cut-out.
        Den
