What fuse rating for each holder?
    There is a dedicated radio supply (Pink/White) behind the carpet beside the centre console, driver's side. This is live when the ignition switch is in the first (Aux) position so that you can listen to the radio with the ignition switched off. Whichever supply you use, you should have an inline fuse (max 5amp) to protect the unit. If your radio unit requires a permanent live to power the station memory, then this too should have an inline fuse (max 5A)
    Legend, thank you!
