front wheel alignment (Adjusting the toe)
    Posted this question before, I got an answer but cant find it now.
    I made a make shift caliper out of gas pipes to measure the distance between front edge of front wheels to the distance between back edge of front wheel. I have about 1/2'' gap. Toe out. If I rotate one tie rod by one full rotation, by how much can I reduce or increase the gap?
    If I am performing a crude adjustment, is it better to have a small toe in or small toe out?
    Thx in advance. Sujit
    Spec is 1/16” to 1/8” toe in.
    I would adjust both sides equally or it will affect your steering wheel position.. unless you wanted to adjust that!
    found your original post.
    I'm trying to align my front wheels myself. I do plan to take the car to a shop at a later date to get every thing aligned at a later date. I made a make
      thx
        If you rotate the one tie rod by one full rotation then that rod will alter by 1/20 " as its either 7/16 or 1/2" UNF with 20 tpi. How much that will reduce your gap all depends what size of wheel you have. As that is a Trigonometry question.
