I said in a early post that since fitting the weber carb I couldn't get the car to change gear properly .I have since played with the cable adjustment a lot and re routed the cable from the position I had it in and now it is better but still not right .I find that itwill notchange to 3rd under 2500 revs and then only if I take my foot off the pedal .so I assume that the problem is in the box end, what I need to know is how easy is it to adjust in the box the ROM tells you what to look for butdo notsay what to do if all is not as it should be
JOHN
JOHN
