Years back when I got my Stag, the PO installed an oil pressure gauge. They had removed the oil pressure sensor. I went to a junkyard and got a tee from an MGB. (item no. 1 from left in photo) I then went to a hydraulic line shop and they made me a steel braided hydraulic line which I could plumb in. I'm not sure what the fittings on the ends are, but they gave me some adapters for the ends. (Item no. 4 from left in photo) One end of the adapter threads into the hydraulic line, and the other in an NPT. This threads in the oil transfer cover. The other adapter which came with the hydraulic line threads into the tee. The male threads on the tee are not NPT. The photo next to the tee went in the engine block of an MGB. The other end of this thing is not NPT either. Would anyone have a clue what the thread could be on the MGB tee?
The following may also give a clue. I bought a smiths oil pressure gauge. A pipe was included in the kit with some adapters. (The adapter is the third item to the left) One end of this supplied pipe will thread directly into the Tee of the MGB and the other end, threads onto the gauge. In the kit came some adapters which can change one end of this pipe to an NPT thread.
I just bought a new NPT tee and plan to reinstall the oil pressure gauge at the oil transfer cover., but I need to join the hydraulic line to the line which came with the gauge.
Sujit
Sujit
