Hi all , I’d had reason to believe I needed a wheel bearing on the near side of my car due to a wheel bearing type noise , what I noticed on this side whilst I was replacing the bearing was the split pin hole is not sitting at 12.00 o’clock to 6.oo o’clock but at a quarter to three , the other side is at the correct position, does this quarter to 3 position indicate a problem as I can’t locate the noise or it doesn’t matter where the split pin hole is ? Regards Graham
Stub axle
Sorry thought you were on a rear bearing!
still clean &
check to see if there’s more than one hole though there often is for getting correct nut position.
If you are concerned that the stub has twisted, understand that now.
most likely has not.
check the nut behind.
there were recent reports about stub axle shaft fatigue failures.
i believe new stub axle shafts are available.Last edited by jbuckl; 18 August 2020, 22:44.
Yes , I should have said it’s a front wheel , yes I’m concerned that the stub axle could have rotated a bit , or maybe a PO or factory fitted it like that , I’ll undo the rear nut to see if it can be rotated , I’ve owned the car for 26 years , so I’d expect it is the original stub , but I’ve always seen on all stub axle regardless of car the split pin hole is the vertical position 12 o’clock , can confirm there is only one hole
The stub axle can be fitted in any orientation, as it is only a taper fit in the vertical link, with a nut behind. No ‘Woodruff’ key. Every stub axle I’ve seen has 2 split pin holes at 90 degrees to each other which, along with the 6 slots in the castellated nut, gives a huge range of adjustment for the taper bearing.Dave
