I am finally re-assembling the Stag after 9 months of restoration works. Is there supposed to be something between the stainless steel trim and the actual B Post? I note there are two slots on the painted B Post which makes you think something may be attached before the stainless steel trim is screwed on by the small screws on both sides. Appreciate you advice. Thanks.
B Post trim
Originally posted by sujitroy View PostWhen I took some off a parts car, those holes were duct taped over.
As seen on my stripped down Stag
Originally posted by BigHW View PostI am finally re-assembling the Stag after 9 months of restoration works. Is there supposed to be something between the stainless steel trim and the actual B Post? I note there are two slots on the painted B Post which makes you think something may be attached before the stainless steel trim is screwed on by the small screws on both sides. Appreciate you advice. Thanks.
