I'm working on Stag no.2 it it has an early Mk1 manifold and a Mk1 radiator. The top hose has a tee in it with a bleed valve. I'm assuming this is to bleed valve it to remove any air form the top radiator hose. Isn't the radiator cap just as high and can be removed to bleed air.
With this setup, do you need to periodically bleed the system or just once when you fill up the radiator with fluid?
Sujit
Sujit
