Hi Went to get the stag out of the garage and would not start . Checked it over and no spark . Last time out was cutting out on start up but eventually ran ok and took for a run and all seemed ok .
Testing the ignition system . By connecting the blue and black wire only got a weak spark from the coil , changed the coil and spark now good from coil . Tested the optical switch and no spark from breaking the beam with a bit of card . Tested voltages. Have 7.5 v on red wire and 2.5 v between blue and black , piece of card in the beam and voltage is the same .
So I am guessing that the optical switch is faulty . This would be the 2nd one in 18 months .
Rather than buy a new switch was thinking about changing the whole system and have seen a power spark system but I have no experience of them ,or any suggestions what to change for .
thanks .
thanks .
