I've been trying to resolve my hot starting issues. Someone, I think Tony Hart, mentioned to look at the float-chamber ventilation valves and its operation
I have an old set of carbs. in front of me and this is what I've observed. In the normal case, the valve is meant to open one vent passage and close another depending on the throttle. However, If you adjust the throttle to maintain, 800 rpm (BW35), both vent passages are open. I recall when starting the Stag, the throttle should be closed, (I used to pump on the accelerator).
I read the description in the ROM and it's Greek to me what it really does and will it help my hot staring issue and can some please explain what is the purpose of it?
I have carb. setup B
Sujit
Sujit
