ingnition light not working
    when turning ignition on light off car starts light stays off car reving at 2000 revs meter on battery shows 12.2 volts have tried different alternator ignition bulb ok no power shown light cluster with ignition on any ideas please
    Check all connections to the alternator, (and earths), and that there are volts on the excitation feed (small brown and yellow wire). If all OK, then I suspect the alternator is goosed, might just need new slip ring brushes if you fancy delving.
