CLUTCH master cylinder
    Hi all
    I have just received a new clutch master cylinder and there seems to be a slight differance I got the new one from SOC parts, on the push rod there is a ribbed metal sleeve on my old cylinder the end of the sleeve is under the rubber rubber cap, on the new one it is not under the rubber cap on the cylinder, so which is right please???
    thank you
    Martin
    My old one was under. This prevents the rubber chafing on the rod I would assume
      Will the oil leak out of the seel if I do that ??
        It's just a dust cover. the the rod won't fall out as it is held in the cylinder with a circlip.
          the seal to prevent fuild coming out is on the other end of the rod behind the circlip.. it's a cheap simple repair unless the cylinder is old and rusty. you just need a pair of circlip pliers and a repair kit from LD Parts
            Oh no it isn’t...
            Well not on all versions anyway, mine popped out a treat! I shoved it back in smartish and damaged the piston seal, had to get a rebuild kit..
            it was the type with the external dust cover.
            Terry
              Are you sure Terry you are not referring to the clutch slave cylinder? that I call pops out.
                Ha. That will teach me to read from the top! Yes of course. Sorry..
                  Thank you, I have just fitted it the way it came, I just need to bleed it now
