Having made and fitted the PDWA immobilising tool, we bled the brakes yesterday.
My wife noted that when bleeding the rear circuit, the brake pedal only travelled half way to the floor, whereas when bleeding the front, it went all the way to the floor. Is there any reason for this?
Also, I noted that the rear circuit was being fed fluid from the front part of the reservoir and the front circuit was fed from the rear section, so it looks as if someone connected the circuits back to front at the master cylinder compared with what the manual says. Is this likely to be a problem? The brakes perform perfectly well as it is.
Thanks,
Chris
Thanks,
Chris
