Hi
Ive owned my Stag for 20 YRS and slowly but surely worked my way through alot of problems and generally putting things right how they should be,the car has rewarded me with what is now a lovely drive.
One of the last things thats haunted me for 20 yrs I would like to sort out is that when I start the car from cold with full choke,it starts very akwardly on what sounds like 4-6 cylinders, well definately not 8.
The other pots fire up eventually.
The best clue I can give you is that if I just drive the car out of the garage to work on it then drive back in with choke still on,the next time I come to start it roars into life on all 8 and sounds lovely.
This tells me that there is some left over fuel in the bores/manifold and that this aids statrting .
I think my choke mechanism is set up correctly as I did it via the haynes manual,full choke revs at about 1,500 rpm.
I think the fact is starts well after a garage in and out session and not starting from cold after putting back in garage after a journey,tells me that that maybe there is some fuel starvation at starting from cold and this causes the aforementioned lumpy starting.
My question is does any one else suffer this,and can anyone recommend an answer,?
Thank you in advance
Mark
Mark
