Hi,
Okay, as you can see from my Avatar my Stag is a work in progress and at the moment only gets driven from my garage onto the drive when I want to work outside. As the fuel light has been on for some time, I thought it was time to put some fuel in. Now I find the problem is none of the keys appear to unlock the filler cap (first time I've needed to fuel it). :?
The barrel is designed for a key that is cut top and bottom, which from the keys I have is only the ignition key. This fits all the way into the lock but won't turn. (The other keys fit the boot and glove box). So for now I have added some fuel by removing the sender unit.
Anyway, I have now removed the filler cap, but still can't find a way to open it, even if it's to remove and change the lock. Can anybody help?
Thanks, Jeremy
Thanks, Jeremy
