Pwda
    Pwda
    Hi all, bit of a long shot. As you can see from the photo the wire has decided to detach itself. Has anybody got a spare top half with the wire connected? Any suggestions welcome. Cheers mark
    If you can live without the top bit, then just connect a female Lucar connector to the wire and plug it across the two pins of the switch. You could remove the existing connectors inside the top bit and hide the Lucar connector inside.
      Many thanks for the reply DJT, At least I have options now. cheers Mark
        Robsport might have one.... Tr7 was the same.
          on my stag there is a wire bridge between the two pins
            Also some Jaguars, Rovers and Land Rovers....
              Just an update...............Shaved the rubber from the wiring connector and soldered on new wire. Many thanks for all replies and to Martin (M&M) for advising on this repair. Mark
