Hi all - I'm currently preparing to reunite my engine and BW65 box in readiness for re-installation into the car. I thought I'd make things easier by buying a new kit of bell housing bolts, rather than try to figure out the motley collection of what had been removed. The kit I bought from one of the UK suppliers consisted of 12 x 5/16 UNFx1.75" long bolts together with nuts and spring washers - which appears mostly consistent with what is shown on page 03-02 of the parts manual (apart from the fact that the manual differentiates two of the bolts - p/n 157274 instead of HB814, though I cannot find a description anywhere of 157274). Looking at what is actually needed for the job, the 6 x uppermost fixings (1 - 6 in the photo) are made into blind holes in the engine block, and while the bolts supplied are compatible with these, the nuts are superfluous to requirements. Fixings 7 - 12 are through-holes, each requiring a bolt and nut, though the length supplied is excessive - in fact they are too long to use for fixings 7 & 8 due to insufficient clearance behind the engine plate. I'm confused by the fact that the kit supplied is incompatible with what I need, but more so by the fact that what I have is inconsistent with what appears in the parts manual.
Can anybody offer any advice based on their own experiences? Thanks in advance.
