Before I took my car off the road the overdrive was not working. When I removed the gearbox I noticed that the small harness from the gearstick switch was damaged so I assume the problem lay there. I have bought a new harness for the gearstick and a new harness for the gearbox. I am currently cleaning up the gearbox before I fit it and would like to check the solenoid before I do this. Would I be right in assuming that if I connect a 12V battery directly to the solenoid I should hear the solenoid moving. Pic below of gearbox showing reverse and overdrive switch.
