Soft top washer and bolt dimensions
    I went to looked in the technical section but couldn't find this. Does anyone have the thickness' of the various washer used and the bolt lengths and shoulder lengths used on the soft top?
    Regards, Sujit
    The bolts I have posted, there's also info on a site that may list the dimensions.
    I took my hood frame apart last night, then realised that I need it to identify what bolty goes where... It took a lot longer to reassemble I can tell you! At least this time I knew which pictures I really need to take:D So I'm looking at the Rimmer and factory parts lists, and the pivot bolt location is a bit vague to me.. I
    Aside from the really thick washers they are all pretty much all the same, but thin shim washers will be needed to make them fit tightly. I bought a few packs of assorted thickness 3/8" "arbor shims" online, they were not overly expensive, i think $8 for a pack of 10.
    Terry
