Hi,
as I wrote in my last posting (https://www.socforum.com/forum/forum...to-body-gasket) I was working on the rear lights.
I changed the gaskets and the lenses. Therefore I had to remove the reflector-inserts which were glued to the old lenses. I then glued the reflector-inserts to the new lenses using a type of instant glue.
After reassembling everything looked okay. But this morning (5 days later) I found this:
The glue seems to have disolved the plastic of the lenses.
I'm pretty shure, that I have not smudged the lenses with glue.
It also looks like the surface of the reflector-inserts is affected.
So, my questions are:
- Why are the reflector-inserts glued into the lenses? Is it possible and allowed to inlay them like the other inserts?
- What type of glue should I use to glue the reflector-inserts to the lenses (which I now have to buy again)?
- Are the inserts (especially the reflector-inserts) available somewhere?
Any advice will be appreciated.
Gerd
I'm pretty shure, that I have not smudged the lenses with glue.It also looks like the surface of the reflector-inserts is affected.
Gerd
