stag heater problam???
    when i put the blower on it just blows cold, is this a blockage in the heater and is it fixable, im new on here so plz be gentle, thanks,plz help:?
    Hi if you type 'heater valve' into the search box you can read many previous threads on this topic.. Lets just say you are not alone
    Darren
      could be just a cable problem like it has come off or snapped
        Hi,
        Has the car been standing over the winter! I had the same problem. heater valve had become stuck and when the lever on the dash was moved it just bent the cable. I freed the valve of by gently moving it back and forth with a spanner (have the car warmed up it expands the brass and makes it easier to free off)once you have done that if you take the ashtray out and the heater control panel off, you can get limited access to the cable and straighten it. If that's the problem of course!
        Hopes this helps,
          will do thanks alot
            Hi, welcome to the humoursorium, all human and Stag owning life is here, you must be a good bloke 'cos you own a Stag, so thrice welcome. A name and rough location would be good - and keep your sense of the rediculous to hand ! Martin.
              thanks martin will update asap,my name is lyndon and im from birmingham, water orton
                Thanks mate, nice to meet you ! Another possibility is short runs and a shot thermostat - just a thought. Martin.
